Integrating Mitsubishi Heat Pump with SmartThings: A Positive Experience
I’ve recently taken on the challenge of integrating my Mitsubishi Heat Pump with SmartThings, and I’m thrilled to share my journey and findings! :star2:
After some research, I stumbled upon the node-mmcontrol project, which seemed like the perfect solution. Though I’m not a coding expert, I found the community support and documentation incredibly helpful. Thanks to the guidance from forums and GitHub, I managed to set it up without too much hassle! :bulb:
Here’s what worked for me:
  1. Installation: I started by installing the necessary software and setting up the Wi-Fi adapter for my heat pump. It was surprisingly straightforward!
  2. Integration: Using the node-mmcontrol library, I configured the integration with SmartThings. The process was smooth, and within a few hours, I had full control over my heat pump through the SmartThings app! :iphone:
  3. Benefits: Now, I can adjust my heating settings remotely, set schedules, and monitor energy usage—all from my smartphone. It’s been a game-changer for managing my home comfort efficiently! :thermometer:
I’d love to hear from others who’ve successfully integrated their Mitsubishi Heat Pumps or have tips for those looking to do the same. Let’s keep the positive momentum going! :muscle:
Cheers, Mark
Hi Mark, Mark here… I would like to do exactly what you did, link my Mitsubishi control app to SmartThings. I found the GitHub node-mmcontrol but have no idea where to go from there. Can you point me in the right direction? Thanks!
