Hello everyone, I wanted to share my recent experience integrating multiple camera brands into my Home Assistant setup. I’ve always been a bit hesitant about relying on cloud services, so I decided to go for a more decentralized approach. Here’s how I made it work!
The Goal
I wanted to have both indoor and outdoor cameras that I could fully control through Home Assistant. Additionally, I wanted the ability to stream footage to my own cloud storage when motion is detected. This way, I keep control over my data while still having the convenience of remote access.
The Challenge
Initially, I was using an LSC Smart Connect camera, but it only worked with Tuya’s cloud service, which I wasn’t comfortable with. After some research, I found that cameras with built-in RTSP support would be the way to go. These cameras allow direct integration with Home Assistant without needing a third-party cloud.
The Solution
Here’s what I did:
Camera Selection
- I chose cameras from brands like Reolink and Arlo, which are known for their RTSP support and compatibility with Home Assistant.
- These cameras are also compatible with my existing Z-Wave network, which simplifies control and automation.
Integration Process
- I followed the official Home Assistant documentation to set up the cameras. The process was surprisingly straightforward, especially with the help of the
RTSPintegration. - For motion detection, I set up a simple automation that triggers when motion is detected, recording the footage and uploading it to my own cloud storage.
Custom Automation
- I created a custom automation that notifies me via Telegram when motion is detected, along with a live stream link. This has been incredibly useful for monitoring my property while I’m away.
Lessons Learned
- Decentralized Systems Are Key: By avoiding proprietary cloud services, I’ve gained more control over my data and reduced potential security risks.
- Community Support: The Home Assistant community is amazing. If I had any issues, the forums and Discord channels were always there to help.
- Documentation is Your Friend: The official documentation saved me countless hours. Always start there before diving into more complex setups.
Integrating multiple camera brands into Home Assistant was a bit of a challenge, but the result is a seamless and secure home security system. I highly recommend exploring RTSP-supported cameras if you’re looking to avoid cloud dependency.
If anyone has questions or needs help with similar setups, feel free to reach out! Happy automating! ![]()
