Hi everyone! I’ve been diving into the world of home automation lately and wanted to share my experience with integrating multiple devices into my Home Assistant setup. I’ve been curious about the best way to combine different brands and systems, so I thought I’d document my journey and maybe help others along the way.
My Setup
I’ve got a mix of devices from various brands—MyQ for the garage door, Sonos for music, and a few Tasmota-flashed devices for added functionality. Initially, I was a bit overwhelmed by how everything would work together, but with some research and experimentation, it’s come together beautifully.
Challenges and Solutions
One of the first hurdles I encountered was getting the MyQ garage door sensor to play nicely with my driveway gate. The standard sensor was designed for vertical movement, but my gate operates horizontally. After some research, I found a workaround by DIY-ing a custom sensor that communicated with MyQ. It was a bit tricky, but seeing it all work seamlessly was incredibly rewarding!
Automation Tips
I’ve also been exploring automations, especially with my Sonos system. I discovered that clearing out my favourites list resolved an issue where the integration wasn’t starting correctly. It’s a small tweak, but it made a world of difference. If anyone else is having trouble with their Sonos integration, checking the favourites list is a quick fix worth trying.
Another tip I’d like to share is simplifying automations by combining states. I used to have multiple automations for different scenarios, but consolidating them into a single setup has saved me a lot of time. For example, instead of having separate automations for each state change, I now use a more comprehensive approach that covers all necessary transitions. This has made my setup cleaner and easier to manage.
Community and Feedback
I’d love to hear from others who have successfully integrated multiple devices or have tips for optimizing automations. The community here is amazing, and I’ve learned so much from others’ experiences. If you’ve got a hack or a solution that’s worked well for you, please share! Let’s keep the knowledge flowing and help each other create smarter homes.
Thanks for reading, and happy automating! ![]()
