Integrating Multiple Smart Devices: My Experience and Tips
I’ve been on a journey to integrate various smart devices into my home ecosystem, and I wanted to share my experiences and tips with you all. :star2:
Introduction
Starting with the basics, I decided to go with the Shelly 1 and Fibaro motion sensor. These devices promised seamless integration, but I encountered some hurdles along the way. Let me walk you through my experience.
Challenges and Solutions
  1. Shelly 1 Power Management: Initially, I struggled with the power consumption of the Shelly 1. It drained my 9V battery faster than expected. After some research, I found that adjusting the settings to minimize standby power usage significantly helped. If you’re using a battery, consider using a larger one for a longer lifespan.
  2. Fibaro Motion Sensor Integration: Upgrading from an older Z-Wave setup to the Fibaro motion sensor was a breeze, but I noticed that the temperature and lux sensors weren’t showing up as expected. After some digging, I realized that the new entity IDs were different. I had to manually adjust the frontend settings to display all sensors properly.
Tips for Integration
  • Device Compatibility: Always check the compatibility of your devices with your hub before purchasing. I learned this the hard way with a device that didn’t integrate smoothly.
  • Regular Firmware Updates: Keep your devices’ firmware updated. I noticed a significant improvement in performance after updating my Shelly 1.
  • Battery Management: If you’re using battery-powered devices, invest in a good battery monitor to keep track of their status.
Conclusion
Integrating multiple smart devices can be challenging, but with the right approach and a bit of patience, it’s incredibly rewarding. I’m now enjoying a more connected and efficient home environment. If you’re planning to integrate devices, start small, and gradually expand your setup. Happy integrating! :rocket:
