Integrating Multiple Smart Switches and Automations: A Success Story
I’ve been on a journey to integrate several smart devices into my home automation setup, and I’m thrilled to share my experience! :tada:
Recently, I decided to add three Sonoff switches controlled by Tasmota to my Home Assistant system. While setting them up, I encountered a common issue—only the last switch appeared in my configuration after a restart. After some research, I realized I was duplicating the switch platform in my config.yaml file. Once I corrected that by nesting all switches under a single switch platform, everything worked seamlessly! :rocket:
For anyone looking to achieve dynamic lighting based on time of day, I’ve implemented a solution using AppDaemon. It automatically adjusts brightness and color temperature throughout the evening and night. For example, it starts bright at 100% in the early evening, dims to 50% mid-evening, and goes even lower at night. This has been a game-changer for late-night trips to the bathroom without blinding me! :sleeping:
Here’s a quick tip for anyone setting up similar automations: consider using a single AppDaemon script with configurable parameters for each light. This keeps your setup clean and easy to maintain. :hammer_and_wrench:
Would love to hear how others are automating their homes and any tips you’ve picked up along the way! Let’s keep the smart home innovations flowing! :bulb:
