I’ve been diving into the world of home automation lately, and integrating Mycodo with Home Assistant has been an exciting journey. For those who aren’t familiar, Mycodo is an open-source automation software that’s perfect for controlling things like climate systems, cameras, and more. I’ve been using it alongside Home Assistant to manage my smart devices, and it’s been a game-changer for me.
Let me walk you through my setup. I have two climate controllers running Mycodo, and I wanted to integrate them seamlessly into Home Assistant. The first one worked out of the box—simply adding the API key and boom, all the data started flowing in. It was so smooth that I didn’t even need to troubleshoot much.
The second controller was a bit trickier. I tried adding it the same way, and at first, it seemed to work. I could see the data from both controllers in the Home Assistant dashboard. But then, after a restart, everything changed. Home Assistant only recognized the second controller, and the first one was nowhere to be found. That was a bit frustrating, to say the least.
I decided to dig into the logs to see what was going on. It turns out that Home Assistant was getting confused between the two API keys. It was treating them as the same entity instead of two separate ones. After some research, I found that the issue was with how the Mycodo integration was set up. I needed to create separate configurations for each controller instead of trying to add them both under the same integration.
Here’s what I did: I went into the configuration.yaml file and added two separate entries for Mycodo, each with their own API key and device IDs. This way, Home Assistant treats them as two distinct integrations. It took a bit of trial and error, but finally, both controllers were recognized without any issues.
This experience taught me the importance of checking the configuration files when integrating multiple devices. It also highlighted how powerful Home Assistant is when it comes to handling multiple integrations, as long as they’re set up correctly.
If you’re looking to integrate Mycodo with Home Assistant, my advice is to take it one step at a time. Test each integration separately before trying to combine them. And don’t hesitate to check the logs if something doesn’t work as expected. The community forums are also a great place to ask for help if you run into any roadblocks.
Overall, I’m really happy with how everything is working out. My home automation setup is more robust now, and I can’t wait to add more devices to it. If you have any questions or tips about integrating different systems, feel free to drop a comment below! Happy automating! ![]()
