I recently purchased three Nest smoke detectors and have been thoroughly impressed with their performance. The ability to integrate them into my OpenHAB setup has taken my home security to the next level. I wanted to share my experience in case it can help others who are looking to do the same.
Initially, I followed the standard OpenHAB documentation to set up the Nest binding. I installed the binding, created a product, and configured the necessary permissions. Everything seemed to be working smoothly—logging in with the correct ID, secret, and PIN worked without any issues. However, when I tried to create an item to monitor the smoke sensor’s status, I encountered an error: Unable to get state from data model.
After some research and troubleshooting, I realized that the issue might be related to how the item was configured. I revisited the documentation and adjusted the item definition to ensure it was correctly referencing the smoke sensor’s name. Here’s the corrected item configuration I used:
plaintext
String NestSmoke_name “Name [%s]” (gHallwaySmokeSensor) {nest=“<[smoke_co_alarms(Eingangsbereich).name]>”}
This adjustment resolved the error, and now the smoke detector’s status updates correctly within OpenHAB. I was then able to create a simple rule that triggers an alert and activates all the lights in the house if the smoke alarm goes off. It’s a small but crucial addition to my home’s safety system.
For anyone else looking to integrate Nest devices into OpenHAB, I recommend carefully reviewing the item configurations and ensuring that all permissions and API settings are correctly set up. The Nest integration is incredibly powerful, and with a bit of tweaking, it can seamlessly enhance your smart home setup.
If you have any questions or need further assistance with OpenHAB configurations, feel free to reach out! Happy automating! ![]()
