I’ve been using Google’s Temperature Sensors with my Nest Thermostat for a while now, but I’ve always felt limited by their compatibility issues with Home Assistant. They work okay, but managing schedules and controlling the thermostat feels clunky. So, I decided to give the Shelly H&T sensors a try, and I’m thrilled with the results!
Initially, I was a bit nervous about integrating these sensors with my Nest Thermostat. I’m not a developer, so I wanted to keep things simple. My plan was to create automations for each Shelly H&T that would tell the thermostat when to start heating or cooling based on specific temperatures. I’d control which sensor was active by turning on its automation and turning off the others. I even thought about creating a dashboard for easier management.
But before diving into all that work, I reached out to the community for advice. I was worried that this setup would make the thermostat’s own temperature readings irrelevant, except for its immediate surroundings. Thankfully, the community suggested a better approach! Instead of relying solely on the Shelly sensors, I can configure Home Assistant to display the temperature from the active Shelly sensor on the Nest thermostat itself. This means I get the best of both worlds: the precision of the Shelly sensors and the convenience of the Nest thermostat’s interface.
The process was smoother than I expected. I used the Home Assistant GUI to set up the automations and integrations. There was a bit of trial and error, but the community was incredibly supportive. Now, my thermostat seamlessly switches between sensors, and I can control everything from the Home Assistant dashboard. It’s a huge improvement over my previous setup!
If you’re considering making the switch to Shelly H&T sensors with your Nest Thermostat, I highly recommend giving it a try. It’s a great way to enhance your smart home setup without losing the convenience of your existing devices. Plus, the flexibility to switch between sensors means you can always get the most accurate temperature readings for your space.
I’d love to hear how others have integrated their Nest Thermostats with different sensors. Share your experiences below—I’m always looking for new tips and tricks to make my setup even better!
