I’ve been on a mission to integrate my old wired door sensors with my MCV VeraLite system, and I’m thrilled to share my journey and success with you all!
The Challenge:
Like many of you, I have a 15-year-old security system with wired door sensors that I wanted to utilize without upgrading to a new security system. The goal was to repurpose these sensors for VeraLite scenes without subscribing to a monitoring service.
The Solution:
After some research and experimentation, I discovered that VeraLite allows for custom sensor integration through its rule engine. By using the existing sensors, I configured VeraLite to trigger specific scenes when the sensors detect motion or status changes. This involved setting up custom events and creating automation rules within VeraLite’s interface.
The Setup:
- Wiring: I connected the old sensors to VeraLite’s input ports. This required some basic wiring knowledge, but the VeraLite documentation made it straightforward.
- Configuration: VeraLite’s rule engine was key. I set up rules to trigger lights, notifications, or even adjust thermostat settings based on sensor inputs.
- Testing: I tested each sensor to ensure they were correctly detected by VeraLite and that the corresponding scenes were triggered as expected.
The Result:
It’s been a week since I completed the setup, and everything is working seamlessly! My old door sensors are now integral to my smart home ecosystem, providing reliable and efficient automation without the need for a new security system.
Tips for Others:
- Documentation: VeraLite’s user guide and online forums were invaluable. Take the time to thoroughly understand your system’s capabilities.
- Patience: Integration can be trial and error. Be patient and test each component individually before setting up complex scenes.
- Community Support: Don’t hesitate to reach out to forums like this one for advice. The community is incredibly helpful!
Final Thoughts:
This project has been a rewarding experience, demonstrating how older technology can be repurposed with modern smart home systems. It’s a testament to the adaptability and potential of VeraLite and similar systems.
If anyone has questions or needs guidance, feel free to reach out! Happy automating! ![]()
