Integrating Philips Hue with CCU Firmware: A Smooth Experience
I’ve always been fascinated by the idea of seamlessly integrating different smart home devices, and recently, I decided to dive into the world of Philips Hue and CCU. After upgrading my CCU firmware, I was thrilled to see that Philips Hue devices were now supported out of the box. However, I ran into a small hiccup—I wanted to group multiple Hue devices together to control them as a single unit, but I wasn’t quite sure how to go about it.
After some research and a bit of trial and error, I found the solution! It turns out that grouping devices is not only possible but also quite straightforward once you know the right steps. I was able to set up a group that controls all my lamps simultaneously, which is perfect for creating ambiance or simply turning everything off with a single command.
This experience has been a great reminder of how powerful smart home integration can be when everything works together smoothly. If anyone else is looking to group their Philips Hue devices or has tips on optimizing this process, I’d love to hear about it! Let’s keep sharing and learning from each other. :star2:
