I’ve been really impressed with how Presence and Life360 have allowed me to create a seamless smart home experience. I wanted to share my setup and a tip that might help others looking to achieve similar results.
The Goal:
I wanted my porch light to turn on when I arrive home and then automatically turn off after a set amount of time. This way, I don’t have to remember to switch it off, and it adds an extra layer of convenience to my daily routine.
The Challenge:
At first, I noticed that while the porch light would turn on when I arrived home, it would stay on indefinitely. I wanted a way to set a timer so that the light would switch off after, say, 15 minutes, without affecting the functionality when I was away.
The Solution:
After some research, I discovered that using a combination of the SmartLighting app and a custom smartapp could achieve this. Here’s how I set it up:
Integration with Presence:
- I linked my porch light to the Presence app via Life360. This meant that whenever I (or my family) arrived home, the porch light would automatically turn on.
Setting Up the Timer:
- I created a smartapp rule that triggers when the porch light is turned on by the Presence integration. This rule includes a timer that turns the light off after 15 minutes.
Ensuring Manual Control Doesn’t Interfere:
- I made sure that if I manually turned the light on while I was home, it wouldn’t interfere with the timer set by the smartapp. This was important to avoid frustration if I turned the light on for a quick task and didn’t want it to turn off immediately.
The Result:
This setup has been a game-changer for me. It adds a touch of convenience and security to my home without requiring constant manual adjustments. Plus, it’s been a great way to experiment with smart home automation and explore the potential of integrating different apps and devices.
If anyone has questions about setting this up or suggestions for improvement, I’d love to hear from you! It’s amazing how these tools can make our lives a bit easier and more connected.
