Hey everyone, I’m excited to share my journey of integrating the Shelly 1 PM button into my smart home setup. After some trial and error, I managed to get everything working smoothly, and I want to walk you through the process in case you’re looking to do something similar!
The Goal: I wanted to use my Shelly 1 PM button to trigger specific scenes in my smart home. Whether it’s turning on the living room lights, adjusting the thermostat, or activating a custom routine, I wanted a simple, one-touch solution.
The Setup: I started by ensuring my Shelly button was properly connected to my network. Using the Shelly app, I configured it to work seamlessly with my Home Assistant setup. The next step was creating the scenes I wanted to trigger. For example, I set up a ‘Good Morning’ scene that turns on the lights, starts the coffee machine, and adjusts the thermostat to a comfortable temperature.
The Challenge: Initially, I faced some issues where the button wouldn’t consistently trigger the scenes. After some research and troubleshooting, I realized the problem was with how the button was integrated into my automation rules. I had to ensure that the button’s events were correctly mapped to the desired scenes.
The Solution: I adjusted my automation settings to explicitly link the button’s press events to the specific scenes. This involved tweaking my configuration files and ensuring that the Shelly button’s state changes were correctly recognized by my system. After these adjustments, everything worked like a charm!
Key Takeaways:
- Configuration is Key: Make sure your button is correctly configured in both the Shelly app and your smart home platform.
- Scene Mapping: Spend time setting up clear and specific scenes. This makes automation much more effective.
- Testing: Don’t skip testing each component individually before setting up the full automation. This helps identify and fix issues early on.
I hope this guide helps you integrate your Shelly 1 PM button into your smart home setup. If you have any questions or run into any issues, feel free to reach out! Happy automating! ![]()
