I recently embarked on a project to automate my home’s roller shades using the Shelly 2.5 device, and I wanted to share my experiences and insights with the community. The goal was to replace the existing manual controls with a smart system that allows individual and group control via touch switches, a central switch, and integration with Alexa. Here’s how I approached it:
Project Overview
I have five roller shades in my living room, each needing独立 control. I wanted a system where each shade can be operated individually using touch switches, while also having the ability to control all shades simultaneously with a central switch. Additionally, integrating Alexa for voice control was a must.
Choosing the Right Components
I decided to use the Shelly 2.5 for its versatility and compatibility with multiple protocols. The main question was whether to use touch switches or traditional toggle switches. After some research, I opted for touch switches for their sleek design and ease of use. However, I also explored toggle switches to understand their behavior in different scenarios.
System Design and Challenges
One challenge I encountered was ensuring seamless operation when switching between individual and group controls. For instance, if a toggle switch is in the middle of a movement and a group command is issued, the system needs to handle this gracefully without causing conflicts. I found that the Shelly 2.5 handles this well by queuing commands and executing them sequentially.
Another consideration was energy efficiency. I wanted the motors to shut off once the shades reach their end positions, preventing unnecessary power consumption. The Shelly 2.5’s built-in features made this straightforward, as it automatically cuts power once the end position is reached.
Central Control and Alexa Integration
For the central control, I considered using an I3 switch but decided against it due to compatibility concerns with the Shelly 2.5. Instead, I opted for a custom solution using a Raspberry Pi and a relay module, which provided the necessary flexibility and scalability. This setup allows me to control all shades simultaneously with a single command.
Alexa integration was seamless using the Shelly app and Alexa skills. I can now ask Alexa to open or close specific shades or all of them at once, which has greatly enhanced the convenience of my smart home setup.
Lessons Learned and Tips
- Plan Ahead: Spend time mapping out the control logic and potential scenarios to avoid conflicts.
- Test Individually: Before integrating everything, test each component individually to ensure smooth operation.
- Use Quality Components: Invest in reliable switches and wiring to prevent unexpected issues.
Conclusion
This project has been a rewarding experience, and I’m thrilled with how the system performs. The combination of Shelly 2.5, custom relays, and Alexa integration has created a robust and user-friendly roller shade control system. I hope my journey inspires others to embark on similar projects and feel confident in their ability to tackle complex automation tasks.
If anyone has questions or suggestions, I’d be happy to discuss further!
