Integrating Shelly Dimmer 2 with Berker Switches: A Smooth Experience
I recently embarked on a project to integrate my Shelly Dimmer 2 with Berker switches in my hallway, and I must say, the journey was both enlightening and rewarding. Let me share my experience and some tips for those looking to do the same!
The Setup
I have two Berker switches in my hallway configured as a toggle setup without a neutral wire. My goal was to replace the traditional switches with smart functionality using the Shelly Dimmer 2. The setup involves controlling five Philips LED lights, each rated at 3W, ensuring a bright and energy-efficient lighting solution.
Challenges and Solutions
Initially, I faced some confusion with the wiring configuration. The Shelly Dimmer 2 requires careful connection to ensure both switches function seamlessly. After some trial and error, I discovered that swapping the connections between SW1 and SW2 on the Shelly unit resolved the issue where only one switch was operational. This adjustment allowed both switches to control the dimmer effectively.
Key Insights
  1. Wiring Configuration: Ensure that the connections between the switches and the Shelly unit are correctly set up. Miswiring can lead to only one switch functioning, which was my initial hurdle.
  2. Neutral Wire Workaround: Since my setup didn’t include a neutral wire, I relied on the Shelly’s built-in power management, which worked flawlessly without any additional components.
  3. App Control: The Shelly app provided a seamless experience, allowing me to adjust the lighting remotely and set up schedules for convenience.
Integrating the Shelly Dimmer 2 with Berker switches was a fantastic upgrade to my home’s lighting system. It combines the elegance of traditional switches with the smart functionality of modern technology. If you’re considering a similar setup, I highly recommend thorough planning and, if needed, consulting the Shelly community for support. Happy smartening your home! :rocket:
