I’ve recently taken the plunge into integrating my Shelly Plus 1PM with MQTT, and I must say, it’s been a fantastic experience! For those of you who might be on the fence about diving into MQTT, let me share my journey and some tips that might help you get started.
First off, I was initially hesitant because I’ve heard MQTT can be a bit tricky, especially if you’re not familiar with it. But once I got the hang of it, it was smooth sailing! The Shelly Plus 1PM is an amazing device on its own, but combining it with MQTT really takes it to the next level. I can now monitor my energy usage in real-time, set up custom alerts, and even integrate it with my smart home system for more automation.
One thing I found incredibly useful was setting up the MQTT topics correctly. I had to tweak a few configurations to get everything working seamlessly, but the Shelly documentation was a huge help. I also installed Mosquitto as my MQTT broker, which was surprisingly easy to set up on my Raspberry Pi. If you’re new to MQTT, I’d recommend starting with Mosquitto—it’s lightweight and does the job perfectly.
Another tip I’d like to share is about the JSONPATH transformations. At first, I was a bit overwhelmed by all the options, but once I figured out how to extract the specific data I needed (like power consumption or voltage), it made my setup much more efficient. I also found that formatting the published data with two decimal places made it look cleaner and more professional in my home automation dashboard.
I also want to mention the importance of testing each channel and command carefully. I had a moment where I accidentally sent the wrong command to the device, but thankfully, MQTT’s logging features helped me troubleshoot and fix the issue quickly. Always double-check your topics and payloads before sending them out!
For anyone looking to get started, I’d suggest beginning with a simple setup, like monitoring just one device, and gradually expanding as you become more comfortable. There’s a wealth of resources online, and communities like this one are invaluable for getting advice and sharing experiences.
In conclusion, integrating the Shelly Plus 1PM with MQTT has been a game-changer for me. It’s not only enhanced my energy monitoring capabilities but has also opened up a world of possibilities for smart home automation. If you’re considering this setup, I highly recommend giving it a try—you won’t be disappointed!
Happy tinkering everyone! ![]()
