I’ve been diving into the world of smart home automation lately, and one of the most satisfying projects I’ve tackled is integrating my Somfy motorized balcony shades with Hubitat. It’s been a bit of a learning curve, but the results have been fantastic!
Initially, I was using a remote control (Smoove Origin RTS Somfy Remote) to operate the shades, but I wanted to bring them into the smart home ecosystem. After some research, I discovered that I could use Z-Wave drivers to connect the motorized shades to Hubitat. I downloaded the Somfy ZRTSII Controller and Somfy ZRTSII Node drivers from the Hubitat community forums, and that was a great starting point.
One thing I wasn’t entirely sure about was whether I needed to add the shade motor itself as a device in Hubitat or if I could just use the existing remote control. After some trial and error, I realized that adding the motor as a Z-Wave node was the way to go. It allowed me to control the shades directly from the Hubitat app and integrate them into routines and automations.
For anyone else looking to do something similar, here are a few tips:
- Check Compatibility: Make sure your Somfy motor is Z-Wave compatible or can be controlled via Z-Wave.
- Drivers are Key: The right drivers can make or break the integration. Spend time researching and testing different options.
- Community Support: Don’t hesitate to reach out to forums and communities. There’s a wealth of knowledge out there, and people are usually more than happy to help.
I also stumbled upon some great resources for controlling roller blinds using Shelly devices. If you’re looking to keep things simple, the Shelly 2PM Gen 3 paired with a Shelly Wall Touch Screen is a fantastic option. It’s straightforward to set up and integrates seamlessly with other smart home devices.
If you’re working on a similar project or just starting out, I’d love to hear your experiences or tips! Let’s keep the conversation going and help each other make our homes smarter and more efficient. ![]()
