I’ve recently embarked on a home automation project and decided to switch to smart bulbs for better control and energy efficiency. However, I quickly realized that integrating these bulbs with my existing wall switches posed a challenge. Most of my current setup uses traditional three-way switches and dimmers, and replacing them with smart switches wasn’t an option due to the extensive rewiring required.
After some research, I stumbled upon a potential solution: smart controllers that can work with existing switches without the need for batteries or remotes. The Inovelli smart switch caught my eye, as it seemed to offer exactly what I needed—control over my smart bulbs from the existing wall locations. Unfortunately, it’s currently out of stock, which has been quite frustrating.
I then explored other options, like Zooz dimmers, but I’m still unclear on whether they fully support dimming functionality across multiple bulbs or if they only work with Zigbee devices. Since my setup is primarily Zigbee-based, compatibility is crucial.
In the meantime, I’ve been experimenting with Leviton Decora Smart Switches, but I’m unsure if they provide the two-way communication I need for reliable automation. It seems like a simple solution should exist for this common problem, but finding the right product has been surprisingly challenging.
If anyone has successfully integrated smart bulbs with existing wall switches or has recommendations, I’d be incredibly grateful for the insights! This project has the potential to make my home significantly more efficient and user-friendly, and I’m determined to find the best solution out there.
