After spending weeks configuring my smart home setup, I’m thrilled to share how I finally got all my devices working seamlessly together. My journey began with a challenge: I had devices on both the home and guest networks, but they weren’t communicating as I hoped.
Initially, I set up my main modem with two SSIDs—home and guest—each on separate IP ranges (192.168.1.x for home and 192.168.5.x for guest). On the first floor, I added a router in access point mode, extending the network but keeping the IP range consistent with the home network. This setup worked well for most devices, but I noticed an issue with my air conditioners—they were all on the guest network and weren’t being discovered by Home Assistant.
After some research, I realized the problem was with how Home Assistant detects devices. It relies on IP addresses and device availability, so devices on the guest network weren’t being recognized. I tried a few solutions, including adjusting the router settings and checking the Home Assistant configuration, but nothing worked until I stumbled upon a forum post suggesting a workaround. By setting up a static IP for the AC units and ensuring they were on the same subnet as Home Assistant, I was able to get them recognized.
This experience taught me the importance of understanding network configurations and how different devices interact within a smart home ecosystem. It also highlighted the value of community support—without that forum post, I might still be struggling with this issue.
For anyone else dealing with similar challenges, my advice is to start by checking your network settings and ensuring all devices are on the correct subnet. If you’re using Home Assistant, make sure it’s fully integrated with your network hardware. And don’t hesitate to reach out to the community for help—there’s always someone willing to share their expertise.
Happy smart home tinkering! ![]()
