Hey everyone, I’ve been working on a project to integrate my smart devices more seamlessly into my daily routine. One thing I wanted to achieve was controlling my lights with a simple switch—turning them on with a short press and activating a scene with a long press. I thought it would be straightforward, but it took some time to figure out the right setup.
Initially, I tried using basic automation rules, but they didn’t quite meet my needs. After some research, I discovered that using a smart switch with programmable actions was the key. I ended up using a Shelly Plug S connected to my lights and set up custom actions in my smart home app. It was a bit tricky at first, but once I got the hang of it, it worked like a charm!
Here’s what I did: I programmed the switch to toggle the lights on a short press. For the long press, I created a scene that turns on multiple lights and adjusts the brightness. It’s amazing how this small change has made my mornings and evenings so much smoother. No more fumbling for switches in the dark!
If anyone else is looking to do something similar, I’d recommend starting with a simple setup and gradually adding more features. Don’t hesitate to reach out if you have questions or need help troubleshooting. Happy automating! ![]()
