Integrating Smart Devices: My Journey with Tuya and Hubitat
As a homeowner who’s always on the lookout for ways to enhance my living space, I recently embarked on a journey to integrate some smart devices into my home. My experience has been a mix of challenges and triumphs, and I wanted to share my story in case it can help others navigate similar waters.
First, I wanted to add some smart ceiling fans to my kids’ rooms. After doing some research, I settled on the Globe Caledon ceiling fan/light combo from Lowe’s. It was affordable and came with smart capabilities, which was exactly what I was looking for. However, I quickly realized that there wasn’t a native integration for Globe devices in Home Assistant (HA). This was a bit disheartening, but I wasn’t ready to give up just yet.
After some digging, I discovered that Globe licenses the Tuya IoT platform for their smart devices. This led me to explore the Local Tuya and Tuya Local integrations available through HACS. At first glance, these integrations seemed a bit confusing, as they couldn’t be used simultaneously with the same device. However, I was determined to make this work.
I started with the Local Tuya integration, which required setting up a developer account on the Tuya platform and querying their APIs to uncover the necessary credentials. This process was quite technical and involved, but I found it oddly satisfying to dive into the developer side of things. I successfully managed to turn on and off one of the fans, but the light integration wasn’t as straightforward. I spent hours mapping out the Data Points (DPs) correctly, but the results were inconsistent.
Determined to find a solution, I decided to try the Tuya Local integration. This approach was slightly different, as it queries the Tuya Life app for device credentials rather than requiring a developer account. I was pleasantly surprised by how much smoother this process was compared to the previous one. After obtaining the necessary credentials, I was able to integrate both the fan and light functionalities seamlessly.
One unexpected challenge I faced was the lack of RGB capabilities in the integrated device. After some research, I found a workaround that allowed me to achieve the desired color settings. This experience taught me the importance of perseverance and the value of community support in the smart home ecosystem.
On a different note, I also wanted to share my positive experience with the Hubitat platform. After struggling with SmartThings years ago, I recently revisited Hubitat with their updated features, including HomeKit integration and the Konnected integration. I was pleasantly surprised by how effortlessly everything worked out of the box. My system is now more integrated and reliable than ever, and I couldn’t be happier with the results.
In conclusion, integrating smart devices can be a challenging but rewarding process. It’s important to stay patient, be resourceful, and don’t hesitate to seek advice from the community. If you’re considering adding smart devices to your home, I encourage you to give it a try—you might be surprised by how much it can enhance your daily life!
Happy tinkering! :rocket:
Hi @dINRjsFblg,
It sounds like you explored many paths to get the Tuya and Hubitat integration working as you were hoping it would. In the end it sounds like you found a somewhat simple and efficient method to do this without the Tuya Cloud.
I’m in the process of exploring the same paths you’ve found. I was hoping you might have more information you could share how you were able to make this integration work. I’m curious about the following.
  • Did you use the Hubitat Tuya Integration app?
  • Did you create your own drivers or utilize something already created?
  • Did you happen to do any type of write up on the Hubitat Community on this integration?
  • Did you have use an intermediary app between the Tuya Smart Life app and Hubitat like Tasker?
Any additional information you can provide that would be helpful so that I can follow in your steps to achieve the same Tuya to Hubitat communication would be extremely helpful.
Thanks!
