Integrating Smart Devices: My Recent Project and Learnings
Hi everyone, I wanted to share my recent experience integrating some smart devices into my home setup. It’s been quite a journey, and I’ve learned a few things along the way that I thought might be helpful to others.
First, I recently got a Mi Box and started controlling it with Home Assistant using a Broadlink RM3 Mini. The setup itself was straightforward, but I ran into an issue where I couldn’t get the state of the Android TV unit after starting it. I reached out to the community, and someone suggested using a static internal IP and pinging it to check the status. That worked like a charm! Now, I can start and stop the Mi Box seamlessly through Home Assistant. It’s such a relief to have everything automated without manual intervention.
Another project I’ve been working on involves my Shelly devices. I have three Shelly 1s controlling my garage and garden gates. Initially, I struggled with the gates not responding correctly, especially when I tried to open them without knowing their current state. After some research, I decided to add door/window sensors to each gate. This way, I can create scenes that check the sensor status before opening or closing the gates. It’s a small tweak, but it’s made a huge difference in reliability.
I also wanted to mention my experience with Zigbee devices. I recently added some Konke motion sensors to my setup, which operates on channels 15, 20, and 25. My Zigbee2mqtt gateway was initially set to channel 11, so I had to switch it to 25 to pair the new sensors. However, I noticed that my existing Aquara sensors started acting up. After some trial and error, I found that running two Zigbee gateways on different channels might be a solution, but it’s a bit complex. I’m still exploring this, but I wanted to share my findings in case someone else is dealing with a similar issue.
Lastly, I’ve been impressed by how the community here helps each other out. Whether it’s troubleshooting a device or sharing tips, everyone’s willingness to assist makes this place amazing. If anyone has questions about integrating devices or setting up automations, don’t hesitate to ask—I’m happy to help!
Thanks for reading, and happy smart home tinkering! :rocket:
