Hey everyone, I wanted to share my experience integrating smart lighting across different brands. It’s been quite a journey, but the results are worth it! ![]()
I’ve been using a mix of Philips Hue, Shelly, and Aqara devices in my setup. While each brand has its strengths, getting them to work seamlessly together was a bit of a challenge. For instance, I had trouble setting up my Shelly Rolladensteuer with the Aqara G5 Pro cameras initially, but after some tweaking, everything fell into place. ![]()
One thing I noticed is the importance of consistent naming conventions. I started labeling my devices with clear, descriptive names (e.g., “Living Room Hue Bulb” or “Kitchen Shelly Switch”) to avoid confusion in the Home Assistant interface. This small tip has made managing my setup much easier. ![]()
I also found that using IFTTT or WebCore for automation has been a game-changer. For example, I set up a rule where my Hue lights dim to 30% when motion is detected at night, providing just enough light without being too bright. It’s these little touches that make smart home living truly enjoyable. ![]()
If you’re looking to integrate multiple brands, my advice is to start small, test each component, and gradually expand your setup. Don’t hesitate to reach out if you have any questions or need help troubleshooting! Let’s keep the smart home revolution going! ![]()
