Integrating Smart Lighting with Energy Monitoring
I’ve recently embarked on a journey to integrate my smart lighting system with energy monitoring to optimize both convenience and efficiency. My setup includes Govee smart lights and a Shelly EM power meter, and I’m using Home Assistant as my hub. Here’s what I’ve learned and how I’ve made it work!
Setup and Integration
  1. Smart Lighting: I started by installing Govee smart lights throughout my home. They’re easy to set up via the Govee app and integrate seamlessly with Home Assistant. I love the vibrant color options and dimming capabilities!
  2. Energy Monitoring: To track energy usage, I installed a Shelly EM power meter on my main circuit breaker. It provides real-time data on my energy consumption, which I can view in Home Assistant.
  3. Automation: I created automations in Home Assistant to turn lights on/off based on motion sensors and schedule preferences. For example, lights in the kitchen turn on automatically when I enter in the evening.
Challenges and Solutions
  • Energy Spike Alerts: Initially, I noticed occasional energy spikes in my dashboard. After some troubleshooting, I realized it was due to high wattage appliances like the microwave. I adjusted my monitoring thresholds to account for these spikes.
  • Syncing Lighting Modes: I wanted different lighting modes for different times of the day (e.g., bright during the day, softer in the evening). This required some trial and error with RGB settings and automations, but it’s now working perfectly!
Tips for Others
  • Start Small: Don’t try to automate everything at once. Begin with one room or one type of automation and expand as you become more comfortable.
  • Use Templates: Home Assistant has excellent template sensors that can help you create custom dashboards and automations without needing to write complex code.
  • Community Support: If you run into issues, don’t hesitate to ask for help in forums like this one. The community is incredibly supportive and knowledgeable!
Conclusion
Integrating smart lighting with energy monitoring has been a fantastic way to enhance my home’s functionality while keeping an eye on energy usage. It’s been a learning process, but the results are well worth the effort. If you’re considering something similar, I highly recommend starting with a clear plan and taking it step by step. Happy smartening! :rocket:
