Integrating Smart Switches and Thermostat Efficiency
Hey everyone, I’ve been diving into the world of smart home automation lately and wanted to share my experiences with you all. I recently installed some smart LED panels from Ledvance and connected them to Home Assistant. The integration went smoothly, and it’s been a joy to control my lights through the app. However, my wife prefers using physical switches, which led me to explore some creative automation solutions.
I found a neat way to combine physical switches with smart automation. The idea is to use a switch that can both manually control the lights and be programmed through Home Assistant. This setup ensures that the lights can be toggled either by the switch or through the app, depending on the state of the switch. It’s been a great compromise between traditional and modern controls!
Another project I’ve been working on is optimizing my thermostat for energy efficiency. I received a notification about creating an energy efficiency model, which involves slight adjustments to my thermostat settings. While it’s been interesting to see how the system learns and adapts, I’m curious if others have tips on fine-tuning this process for better accuracy and comfort.
I’d love to hear how you all handle similar setups—whether it’s combining physical controls with smart tech or tweaking your thermostats for optimal performance. Let’s keep the conversation going and share our hacks and insights! :rocket:
