I recently came across a challenge that many of us might face when trying to modernize older homes. The task was to add wireless switches to an existing light fixture without the need for neutral wires or internet connectivity. This is a common request from clients, especially in older properties where running new wires can be both time-consuming and costly.
After some research, I stumbled upon battery-operated wireless switches that don’t require neutral wires. They’re designed to work with plug-in hubs, which means they can be easily integrated into existing setups. The best part? They support multi-way switching, which is perfect for those who need more than one switch to control a single light.
One thing to note is the distance between the light fixture and the new switch location. In my experience, most wireless switches have a reliable range of up to 30 meters, which should cover most home layouts. However, if the distance is greater, it might be worth considering a hub with a stronger signal or adding repeaters.
I’d love to hear from others who’ve tackled similar projects. What solutions have worked for you? Any tips or tricks for ensuring a seamless installation? Let’s share our experiences and help each other out! ![]()
