Integrating Smart Thermostats with In-Wall Heaters: A Success Story
After months of research and experimentation, I’m thrilled to share my success in integrating smart thermostats with my in-wall electric heaters! For those who may be facing similar challenges, I hope this post can provide some clarity and inspiration.
My home features a walk-out basement with three rooms each equipped with a King W2424 240V/2400W heater. These heaters are controlled by external thermostats, and while they’ve served me well, I’ve always wanted to bring them into the smart home ecosystem. The main goal was to automate heating schedules and remotely adjust temperatures, especially when friends or family use the house while we’re away.
The challenge arose when I discovered that many smart thermostats are designed for baseboard or in-floor heating systems and explicitly state they won’t work with forced-air systems. This was puzzling since, in my setup, the heaters either run fully on or off—there’s no partial heating. After reaching out to the community and consulting with more knowledgeable users, I learned that the key concern is safety. Specifically, some heaters are designed to keep the fan running for a few minutes after the heating element shuts off to circulate residual heat. If a smart thermostat doesn’t account for this, it could potentially lead to safety issues.
Armed with this understanding, I decided to proceed cautiously. I opted for Aube relays to connect a low-voltage smart thermostat to the heaters. These relays allow the thermostat to control the heater’s on/off state without interfering with the fan’s operation. After installing the relays and configuring the thermostat, I tested the setup thoroughly. I monitored the system during both heating and cooling cycles to ensure the fan behaved as expected.
The results have been fantastic! The smart thermostat now seamlessly integrates with my home automation system, allowing me to set schedules, monitor usage, and adjust temperatures remotely. Best of all, the safety concerns were addressed by ensuring the fan operates correctly during and after heating cycles.
For anyone considering a similar project, here are a few tips:
  • Prioritize Safety: Always consult with a professional if you’re unsure about the compatibility of your heater and thermostat.
  • Use Relays: If your heater isn’t low-voltage, relays like the Aube models can bridge the gap between your smart thermostat and the heater.
  • Test Thoroughly: Spend time observing the system’s behavior during different modes to ensure everything works as intended.
This project has been a rewarding journey, and I’m excited to see how far I can push the integration of smart technologies into my home. Happy tinkering! :rocket:
