Hey everyone! I wanted to share my recent success in integrating my bTicino Smarther2 thermostat with Netatmo in openHAB. After some research and trial and error, I managed to get everything working smoothly! ![]()
My Journey
I’ve been using the bTicino Smarther2 thermostat for a while now, and while it works perfectly with the Netatmo app, I wanted to bring it into my openHAB setup. Initially, I faced some challenges because the Smarther2 uses a different API than older models. I tried several bindings and even looked into the BTicinoSmarther and OpenWebNet options, but neither seemed to work.
The Solution
After digging through the Netatmo documentation and some helpful forum posts, I realized that the Netatmo binding was the way to go. Here’s what I did:
- Register an Application on the Netatmo developer portal. This gives you the necessary credentials to connect to their API.
- Add the Netatmo Account Thing in openHAB. This was straightforward and worked perfectly.
- Identify the Room ID where my thermostat is located. This was a bit tricky, but I found it by querying the Netatmo APIs directly.
- Create a Room Thing in openHAB, using the correct room ID. Initially, it stayed in the UNKNOWN state, but after verifying the ID multiple times, it finally connected!
Tips for Others
- Double-Check IDs: Ensure the room and thermostat IDs are correct. A small typo can cause big headaches!
- Logs Are Your Friend: Enabling detailed logging helped me troubleshoot why the Room thing wasn’t initializing properly.
- Community Support: Don’t hesitate to ask for help in forums. Someone might have faced the same issue and can offer a solution!
It’s amazing how much I can control and monitor from one platform. Now, I can set my thermostat from my phone, create automations, and even track energy usage—all from openHAB! ![]()
If anyone has questions or needs help with a similar setup, feel free to reach out. I’d be happy to share more details or troubleshoot together! ![]()
Happy automating! ![]()
