Hey everyone, I’ve been diving into integrating some custom software with Home Assistant using MQTT, and I wanted to share my experiences and thoughts with the community. It’s been a fascinating journey, and I hope to get some feedback or insights from those who might have tackled similar projects.
So, to start off, the software in question is currently integrated with Home Assistant without autodiscovery. Right now, it’s set up using MQTT sensors and switches in the configuration.yaml file. The goal is to eventually move this to autodiscovery so that everything can be managed dynamically without manual configuration. But before that, I need to figure out the best way to let Home Assistant know if the software is alive or dead.
I’ve considered a couple of approaches. The first idea is to have the software send a heartbeat every second to a specific MQTT topic, including the current timestamp. Home Assistant would then check if the timestamp is more than 3 seconds old and take action accordingly, like toggling an input_boolean. While this method seems straightforward, I’m a bit concerned about the number of events this would generate in Home Assistant. Plus, I’m not sure how easy it would be to implement this with autodiscovery.
The second approach I’ve thought about is leveraging MQTT’s Last Will feature. From what I understand, this would allow the software to send a message to Home Assistant when it disconnects from the MQTT broker. This could be a cleaner solution since it doesn’t require constant pinging and could be more efficient. However, I’m not entirely familiar with how to set this up, so I’d love to hear if anyone has experience with it.
Another consideration is the possibility of having multiple instances of this software running on the same computer. This means that simply monitoring whether the computer is online won’t be sufficient. We’d need a more granular way to check each instance individually. This adds a layer of complexity, but it’s also an exciting challenge to figure out!
I’d love to hear your thoughts on these approaches or if there are other methods I haven’t considered yet. Is there a preferred way to handle such integrations? Have you encountered similar scenarios and how did you resolve them? I’m also curious if anyone has successfully implemented autodiscovery for custom software integrations and what the process entailed.
This project has been a great learning experience, and I’m excited to see how it evolves. Whether it’s through heartbeats, last will messages, or something entirely different, I’m confident that the community here has some valuable insights to share. Let’s keep the discussion going and help each other out!
Best regards,
