I recently discovered a fascinating way to integrate my Squeezebox Radio’s built-in light sensor into my OpenHAB setup. This integration allows me to automatically adjust the display brightness based on the ambient lighting conditions, which not only enhances the user experience but also prolongs the device’s lifespan by reducing unnecessary strain on the display.Here’s how I achieved this integration:1. Enabling SSH Access: I started by enabling SSH access on my Squeezebox Radio. This was straightforward—just navigate to the settings menu and enable remote login. I made sure to note down the root password for future SSH connections.2. Accessing the Light Sensor Data: Once SSH was enabled, I accessed the light sensor data through the file path /sys/class/i2c-adapter/i2c-1/1-0010/ambient. This file contains the raw sensor readings, which I can use to determine the ambient light level.3. Setting Up OpenHAB: I created a Number item in OpenHAB to represent the light sensor data. This item is configured to update periodically, ensuring that the system always has the most current light reading.4. Automating the Brightness Adjustment: Using a simple bash script, I set up a cron job to periodically read the light sensor data via SSH and update the corresponding OpenHAB item. This script is executed every minute to ensure real-time adjustments.5. Testing and Fine-Tuning: After setting everything up, I tested the integration thoroughly. I monitored the sensor readings and the corresponding brightness adjustments to ensure everything worked as expected. I also fine-tuned the brightness levels to match my preferences for different lighting conditions.This integration has been a game-changer for me. It not only provides a seamless user experience but also demonstrates the versatility of OpenHAB in integrating even the most unlikely devices. I highly recommend this setup to anyone looking to enhance their Squeezebox Radio experience.If you have any questions or need assistance with this integration, feel free to reach out. I’d be happy to help you get started!
