I’ve been experimenting with integrating my Tado X thermostats into Home Assistant using the Better Thermostat integration. It’s been a fascinating journey, but not without its challenges. Let me share my experience and some insights that might help others who are considering a similar setup.
Initially, I was thrilled to discover how seamlessly the Tado X thermostats could be connected to Home Assistant via Matter. The ability to control multiple thermostats from a single interface was exactly what I was looking for. However, when I tried to group three of them into a single Better Thermostat integration to manage the temperature in my living/dining area, things started to get a bit tricky.
The setup itself was straightforward—I followed the instructions to create a Better Thermostat integration and linked it to the three Tado thermostats. The interface looked clean, and I was able to set temperatures and monitor their statuses. But then, the unexpected happened. On several occasions, the target temperature in the Better Thermostat GUI would suddenly drop from a comfortable 22°C to a chilly 9°C. This abrupt change would, of course, cause the thermostats to adjust accordingly, which was both frustrating and inconvenient.
I spent hours troubleshooting, checking logs, and reviewing my configurations. I even considered the possibility of a malfunction in the Better Thermostat integration itself. To rule out any issues with the integration, I tried separating the thermostats into individual Better Thermostat setups. Unfortunately, the problem persisted, which suggested that the issue wasn’t with the integration itself but something else entirely.
After some careful consideration, I realized that the problem might be related to how the thermostats interact with each other when grouped. Perhaps there was a conflict in how the temperatures were being set or monitored. I decided to take a closer look at the automation rules I had in place, just in case one of them was inadvertently causing the temperature to drop. To my relief, I found no automations that were directly responsible for the temperature changes.
This experience taught me the importance of thoroughly testing each component of a system before fully integrating it. While the Better Thermostat integration is a fantastic tool for managing multiple thermostats, it’s crucial to understand how each thermostat behaves within a group. I’m now considering alternative approaches, such as using virtual thermostats or adjusting the way the thermostats communicate with each other.
If anyone has encountered a similar issue or has suggestions on how to stabilize the temperature settings within a grouped Better Thermostat setup, I’d love to hear your thoughts. Let’s continue to explore and optimize our smart home systems together!
