Integrating Tapo T315 with Tado: A Smooth Experience
I’ve been exploring the integration of the Tapo T315 Smart Temperature & Humidity Monitor with my Tado heating system, and I’m excited to share my experience! While the process had its learning curve, the outcome has been nothing short of impressive.
Initially, I was a bit puzzled about how to connect the Tapo T315 to my Tado setup. After some research, I discovered that while the integration isn’t immediately obvious in the Tado app, it’s definitely possible with a few tweaks. The key was to ensure both devices were on the same network and that the latest firmware was installed on both the Tapo sensor and the Tado thermostats.
Here’s a quick tip for anyone looking to do the same:
  • Make sure the Tapo sensor is fully paired with your network and appears in the Tado app’s device list.
  • Check the Tado app’s settings for external sensors and ensure the Tapo T315 is selected as the preferred temperature source.
The result? My Tado system now seamlessly adjusts based on the room temperature readings from the Tapo T315. It’s a game-changer for maintaining consistent comfort throughout my home!
If you’re considering this setup, don’t hesitate to reach out if you need help. I’d be happy to guide you through the process! :star2:
