Integrating the Minoston MR40Z S2 Remote Controller: A Comprehensive Guide
I recently came across the Minoston MR40Z S2 remote controller, and I must say, it’s a fantastic addition to my smart home setup! This battery-powered Z-Wave Plus (S2) scene controller is perfect for those looking to simplify their home automation without compromising on functionality. With its four buttons (two large and two small), it supports up to three presses per button, as well as ‘hold’ and ‘release’ triggers. This makes it incredibly versatile for creating complex scenes and automations.
I decided to integrate this remote into my Home Assistant setup using the Z-Wave JS integration. The process was smooth, thanks to a blueprint I found online, which was inspired by a similar setup for the Remotec ZRC-90. The blueprint essentially maps each button press to specific actions within Home Assistant, allowing for a seamless integration.
Here’s a quick breakdown of how I set it up:
  1. Pairing the Remote: First, I paired the Minoston MR40Z S2 with my Z-Wave controller. This was straightforward, and the remote was recognized almost instantly.
  2. Blueprint Configuration: Using the provided blueprint, I configured each button to trigger specific actions. For example, pressing the top large button once turns on my living room lights, while holding it for two seconds adjusts the brightness.
  3. Testing: I tested each button combination to ensure everything worked as expected. It’s amazing how such a simple device can add so much functionality to your smart home.
  4. Customization: I also explored the possibility of using the ‘hold’ and ‘release’ triggers for more advanced scenarios, like adjusting thermostat settings or controlling my media system.
One thing I particularly appreciate is the battery life. Since it’s battery-powered, I was worried about frequent replacements, but so far, it’s been excellent. The remote also has a detachable decora-sized form factor, making it easy to install or move around as needed.
If you’re looking to streamline your smart home controls without investing in multiple devices, I highly recommend the Minoston MR40Z S2. It’s a cost-effective solution that offers a lot of flexibility and is easy to integrate into existing setups.
For anyone interested in setting this up, I’d be happy to share my configuration details or help troubleshoot any issues you might encounter. Happy automating!
