Integrating traditional devices into a smart home ecosystem can be a rewarding experience, especially when it comes to monitoring and automation. I recently faced the challenge of connecting a Garantia water level indicator to my Home Assistant setup, and I’d like to share my journey and solution with the community.### The ChallengeThe Garantia water level indicator provides a percentage reading of my tank’s fill level, but it wasn’t designed with smart home integration in mind. My goal was to display this data in Home Assistant and automate certain actions based on the water level. After some research, I found that using an ESP32 camera or ESPHome could be the key to achieving this.### The SolutionI decided to use ESPHome, a powerful framework for creating custom IoT devices. Here’s a brief overview of the steps I took:1. Hardware Setup: I connected the water level indicator to an ESP32 module. This involved wiring the sensor to the ESP32 and ensuring proper power supply.2. ESPHome Configuration: I configured ESPHome to read the sensor data. This involved setting up the appropriate pins and libraries to communicate with the water level sensor.3. Integration with Home Assistant: Once the ESP32 was configured, I added the sensor to my Home Assistant setup. This allowed me to view the water level in my dashboard and set up automations based on the readings.### The OutcomeThe integration was a success! I now have real-time monitoring of my water tank’s fill level directly in Home Assistant. I’ve set up automations to notify me when the water level drops below a certain threshold, ensuring I never run out of water unexpectedly.### Tips for Others- Research First: Look into existing tutorials or community discussions before diving into a project. You might find that someone else has already tackled a similar challenge.- Start Small: If you’re new to ESPHome or similar frameworks, start with a simple project to get familiar with the tools.- Community Support: Don’t hesitate to ask for help in forums like this one. The community is incredibly supportive and often provides valuable insights.### Final ThoughtsThis project not only enhanced my smart home setup but also gave me a deeper understanding of how to integrate traditional devices into modern ecosystems. It’s a testament to the versatility of tools like ESPHome and the creativity of the smart home community.If anyone has questions about this project or similar integrations, feel free to reach out! I’d be happy to share more details or troubleshoot any issues you might encounter.
