I’ve been really impressed with the Wyze V3 siren, but I was a bit puzzled about how to incorporate it into my daily routines. After some research and experimentation, I found a great way to make it work seamlessly with Alexa! Here’s how I did it:
First, I set up the Wyze siren as a smart device in the Wyze app. Once it was connected, I used the Alexa app to discover the device. It showed up as a Wyze siren, and I was able to add it to my Alexa routines.
Next, I created a custom routine in Alexa. I wanted the siren to go off when I arm my security system. I added the Wyze siren to the routine and set it to trigger when I say, “Alexa, arm the house.” It worked perfectly on the first try!
I also found that I could use the siren in combination with other smart devices. For example, when I leave the house, I have the siren go off along with my lights turning on and off to give the illusion that someone is home. It’s a great security measure!
One thing I learned is that the Wyze siren works best when it’s placed in a central location. I initially put it in a corner, but the sound wasn’t as effective. Moving it to the center of the room made a big difference.
Overall, integrating the Wyze siren into my Alexa routines has been a huge improvement for my home security. It’s reliable, easy to set up, and adds an extra layer of protection. If you’re looking to enhance your security system, I highly recommend giving the Wyze siren a try!
