Integrating Wyze Headphones with Google Assistant: A User's Journey
Hey everyone! I just wanted to share my experience with integrating my new Wyze headphones with Google Assistant. I recently purchased these headphones and set them up on my iPhone XR. Initially, I was a bit puzzled because when I double-tapped the right ear cup to activate the voice assistant, it defaulted to Apple Siri instead of Google Assistant. I thought maybe there was a setting I missed or perhaps a firmware update needed. After doing a bit of research and checking forums, I found that others had encountered similar issues. It seems that the default voice assistant can sometimes be set to Siri, especially if you’re using an iPhone. To switch it to Google Assistant, I had to go into the device settings on my iPhone and manually change the default voice assistant. It was a bit of a hassle, but once I did that, everything worked smoothly! I’m now enjoying the seamless integration with Google Assistant. If anyone else is having trouble with their Wyze headphones, I hope this tip helps you out. Happy teching! :blush:
