After spending several weeks researching and experimenting, I successfully integrated both Z-Wave and EnOcean devices into my Hubitat ecosystem!
This journey was not without its challenges, but the end result has been worth every moment of frustration. Here’s how I made it happen:
Understanding Compatibility: Initially, I was concerned about compatibility since Hubitat doesn’t natively support EnOcean. However, I discovered that adding a Conexoon gateway as a bridge allowed me to connect my EnOcean devices seamlessly. The Conexoon gateway communicates with Hubitat via Zigbee, which was a game-changer.
Z-Wave Integration: For the Z-Wave devices, I utilized the built-in Z-Wave+ support in Hubitat. Pairing was straightforward, and the devices were recognized almost instantly. It was a relief to see everything show up in the device list without any extra configuration.
Automation Magic: Once all devices were connected, I set up some basic automations to streamline my daily routine. For example, my EnOcean-powered lights now turn on automatically when I open the bedroom window, thanks to a simple rule in Hubitat.
Tips for Others: If you’re looking to integrate multiple protocols like I was, here’s what I recommend:
- Start with one protocol at a time to avoid confusion.
- Invest in quality gateways or bridges if needed—they’re worth the extra cost.
- Take advantage of Hubitat’s robust automation rules to maximize functionality.
I’m thrilled with how everything is working together now. It’s a great feeling to have a fully integrated smart home ecosystem that’s both reliable and easy to use. Huge thanks to the community for all the helpful resources and advice! ![]()
