I recently faced an interesting challenge while integrating my garage door with SmartThings. My garage door uses a Novoferm NovoPort IV system, which operates via a potential-free contact. I wanted to automate the process using a Shelly 1 Mini Gen3, but I also wanted to ensure that the manual switch remained functional in case of any issues with the smart setup.
After some research and experimentation, I found a great solution. The Shelly 1 Mini Gen3 can be connected using L and N for power, and the potential-free contact can be connected via I and O. This setup allows the relay to control the garage door while keeping the manual switch operational. The key was ensuring that the Shelly device was properly configured to handle the potential-free contact without any issues related to SELV (Safety Extra Low Voltage).
Additionally, I wanted to monitor the state of the garage door. I added a magnetic contact sensor, which detects whether the door is open or closed. The sensor’s specifications indicated a max current of 0.3A and a max power of 10W, which are well within the Shelly’s capabilities. I connected it to the Shelly, and now I can easily monitor the garage door’s status through the SmartThings app.
The process involved a bit of trial and error, especially with wiring and ensuring that the Shelly was correctly configured. However, the end result is a seamless integration that combines the convenience of smart home automation with the reliability of a manual override. This setup has given me peace of mind, knowing that I can control my garage door remotely while still having the option to use the physical switch if needed.
For anyone looking to automate their garage door, I highly recommend considering a similar approach. It’s a great way to enhance home security and convenience without losing the functionality of existing hardware.
