Integrating Zigbee Devices with ZBT-2: A Comprehensive Guide
I recently upgraded my Zigbee setup by purchasing the ZBT-2, and I wanted to share my journey and findings with the community. Zigbee has always been a cornerstone of my smart home, but integrating multiple hubs and devices can be quite the puzzle. Let me walk you through my experience and what I’ve learned along the way.
The Setup
Before the ZBT-2, I had a mix of Zigbee devices paired with different hubs:
  • Door sensors and water leak sensors paired with a generic Zigbee hub and a Zegmisart hub, both managed via the Tuya app.
  • Aeotec Dual Nano Switches paired with a SmartThings hub.
  • Zigbee USB extenders to boost the network.
While these setups worked, relying on multiple hubs and internet-dependent apps like Tuya and SmartThings wasn’t ideal. My goal was to consolidate everything under one roof—the ZBT-2.
The Challenge
The big question was: Could I connect my existing hubs to the ZBT-2 without re-pairing all my devices? If not, I’d have to manually re-pair each device, which is tedious, especially for installed light switches.
After some research, I discovered that the ZBT-2 can indeed act as the primary Zigbee controller. However, integrating existing hubs wasn’t straightforward. The hubs couldn’t be directly connected as controllers, but they could potentially serve as routers or extenders in the mesh network.
The Solution
Here’s what I found:
  1. Pairing Devices Directly: The most reliable method was to re-pair all end devices directly to the ZBT-2. While time-consuming, this ensured a seamless Zigbee network without dependency on external hubs.
  2. Using Existing Hubs as Routers: My Zigbee USB extenders and old hubs can still play a role by acting as routers to strengthen the mesh network. This was a relief as it meant I didn’t have to discard my old equipment.
Lessons Learned
  • Mesh Networking: Understanding how Zigbee mesh networks operate was crucial. Each device acts as a repeater, enhancing signal strength and reliability.
  • Hub Compatibility: Not all hubs are created equal. While some can function as routers, others might not integrate smoothly, so compatibility checks are essential.
  • Patience is Key: Re-pairing devices took time, but the end result—a unified, efficient Zigbee network—was worth it.
The ZBT-2 has been a game-changer for my smart home. It’s simplified my setup, reduced reliance on internet-dependent apps, and provided a more robust network. If you’re considering a similar upgrade, I’d recommend thorough research and planning to make the most of your existing hardware.
Let me know if you have any questions or tips on Zigbee integration! Happy automating! :rocket:
