Have you ever wondered how to get the most out of your Zigbee smart plugs in Home Assistant? Let me share my journey and some tips that might help you along the way.
When I first started with Zigbee, I was amazed by the variety of devices available, but I quickly realized that some functionalities weren’t as straightforward as I hoped. One feature I was particularly interested in was tracking daily and yesterday’s power consumption, something I was used to with my old Wi-Fi plugs.
After some research and experimentation, I discovered that while the Zigbee protocol is fantastic for real-time control, it doesn’t natively support the same level of detailed energy monitoring as some Wi-Fi devices. However, there’s a workaround! By carefully configuring your Zigbee2MQTT setup, you can create custom entities that mimic this functionality.
Here’s a quick tip: head over to your Zigbee device settings in Home Assistant and check the available sensors. You might be surprised by what you find. From there, you can use integrations like Node-RED to process the data and create the daily consumption entities you’re looking for.
If you’re into automation, I’d also recommend exploring the configuration through YAML files. It’s a bit more involved, but it offers unparalleled control and flexibility, especially if you’re planning to share your setups on platforms like GitHub.
I’d love to hear about your experiences and any clever tricks you’ve picked up along the way! Let’s keep the conversation going and help each other make the most of our smart home setups. Happy tinkering! ![]()
