iOS 16 Update and Device Naming Issues
Hey everyone, I wanted to share my experience with the iOS 16 update and how it affected my smart home setup. After updating my iPhones, I noticed that notifications from my smart devices stopped working properly. It turns out that the update changed the device names in the mobile app, which broke my existing automations. This was a bit frustrating, but I managed to figure out a workaround.
Initially, my devices had names like “NAME’S IPHONE,” which translated to specific notification IDs in Home Assistant. After the update, these names changed to just “iPhone,” which messed up my automations. I tried renaming the devices through the Home Assistant interface, but it didn’t work as expected. The service didn’t update properly, and the names kept reverting or changing format.
After some trial and error, I found that renaming the devices directly through the mobile app and then restarting Home Assistant helped. This way, the notification IDs updated correctly, and I could manually adjust my automations to match the new names. It was a bit tedious, but at least it worked!
Here are a few tips I learned from this experience:
  • Always double-check device names and notification IDs after major software updates.
  • Keep a backup of your automations in case you need to recreate them.
  • If you’re using custom names, consider documenting them somewhere for easy reference.
I’m hoping that future updates will handle device naming more seamlessly, but for now, this workaround has kept my setup running smoothly. If anyone else is dealing with similar issues, feel free to reach out—I’m happy to help!
