Ios 27 finally supports up to 4k live view
Since ios 27 finally allowes homekit to support 4k quality when will i see it in the aqara app also that the video quality is set to maximum? Because mine still shows 1200p and i cant set it higher
G410 doorbell
@4zk8htq8f4 Great question! I can see the excitement around iOS 27’s expanded HomeKit capabilities, but there are some hardware-level constraints at play here with the G410 specifically.
The G410’s maximum native resolution is actually 2048×1536 (not true 4K), and more importantly, once the doorbell is connected to HomeKit, the resolution gets capped at 1600×1200 due to hardware encoding limitations — this applies to both the HomeKit app and the Aqara Home app simultaneously. So even with iOS 27’s broader 4K support, the G410 itself can’t push beyond that 1200p you’re seeing while paired to HomeKit.
If you want to unlock the full 1536p, you’d need to use the G410 only in the Aqara Home app without HomeKit binding — though that obviously trades off the ecosystem integration.
It’s a bit of a “pick your priority” situation right now: seamless Apple integration with the resolution cap, or max native resolution staying purely within Aqara’s ecosystem. Have you tested whether the resolution unlocks if you temporarily remove it from HomeKit, just to confirm that’s the bottleneck?
