IQ2+ Silent Disarm Solution
Hello everyone, I wanted to share my experience with the Qolsys IQ2 panel and its disarm functionality. My dog has been waking up the entire house every morning due to the disarm voice alert, which has been quite a nuisance. After some research and experimentation, I found a workaround that allows for a silent disarm. Here’s how I did it:
  1. Understanding the Issue: The Qolsys IQ2 panel, by default, announces its disarm status through voice alerts. While there’s a silent arm function available in the ADC app, the disarm feature doesn’t have this option, which was causing the issue with my dog.
  2. Exploring Settings: I thoroughly checked the settings within the ADC app and the panel itself. Unfortunately, there doesn’t seem to be a built-in option for silent disarm. However, I discovered that using a key fob to disarm the system can bypass the voice alert. This method works seamlessly and keeps the house quiet in the mornings.
  3. Alternative Methods: If you don’t have a key fob, another option is to use a different disarm code that doesn’t trigger the voice alert. This requires setting up multiple disarm codes in the system, which can be done through the ADC app’s advanced settings.
  4. Contacting Support: I also reached out to Qolsys support to inquire about adding a silent disarm feature. They mentioned that this is a common request and might be included in future firmware updates. In the meantime, using a key fob or alternative disarm codes is the best solution.
  5. Conclusion: While the Qolsys IQ2 panel doesn’t natively support silent disarm, there are effective workarounds available. Using a key fob or setting up alternative disarm codes can help maintain peace in your home. I hope this solution helps others facing a similar issue.
Thank you for reading, and happy home automating!
