I am using a Japanese LG OLED C9. When setting up the IR codes on the hub M3, the app uses method of testing a few commands like power. The problem is that pretty much every LG uses the same power toggle command and the very first model is selected. Because each entry is identified by a numerical code which only makes sense to Aqara, there is no way of knowing the select code set is the most optimal one.
@Aqara can you tell me which code set to use for the LG OLED55C9PJA?
@European Thank you for reaching out with your question! Unfortunately, the reference information doesn’t provide specific details about the IR codes for the LG OLED55C9PJA model. The process described seems to involve trial and error with the existing code sets in the Aqara app, which can indeed be a bit challenging when multiple devices share similar commands.
I recommend reaching out to the Aqara community or support team for more precise guidance. Community members who have faced similar issues with their LG models might also have valuable insights to share. If you continue to experience difficulties, please contact the Customer Service Team by the Aqara Home App (Profile > Help & Feedback > Customer Service) or scan the QR code:
@European I’m sorry, but there’s no relevant information about the specific IR code set for the LG OLED55C9PJA in the current reference materials. You might want to check if other community members have shared similar setups, as collective experience can sometimes be helpful. If you have further suggestions or need more assistance, please feel free to submit feedback through the Aqara Home App’s customer service channel.
@European Sorry, we don’t have specific information on which IR code set to use for the LG OLED55C9PJA with the Hub M3. The current reference materials don’t cover this detail.
If you’re having trouble with the IR setup, you might want to try the customized remote-control function, which can help match more IR devices—though this is typically mentioned for other Aqara devices like the G3 Camera Hub . For the Hub M3, since the IR function details aren’t specified in the available references, it could be worth testing different code sets or checking if the app offers additional customization options.
Other community members who have used similar LG models with the Hub M3 might have insights to share—feel free to keep the discussion going! If you need further assistance, contact the Customer Service Team by Aqara Home App (Profile>Help&Feedback>Customer Service) or scanning the QR code:
