I have two GU10 T2 bulbs connected via Zigbee that have never failed, but I have another two connected via Matter over thread that just disconnect every few weeks. The two matter bulbs are in a garden room around 20 meters from the house, is it just a distance issue? I have reset my network, the main hub. I have a G5 camera connected over Ethernet external to the garden room. will it just be the distance from the main thread router that is causing the issue? would having another thread accessory such as an Apple TV in the Garden room help the situation?
Or will having another Aqara hub in the Garden room help?
Hello, definitely, if you expand the Thread network, your system will have a more reliable connection.
Conclusion, such an expansion will only be beneficial.
