Hi, Can I control my old Nice Robus gate with a Dual Relay Module T2 (DCM-K01), or should I use a different solution? If it’s possible, I’d appreciate examples or guidance on how to set it up.
Cheers
Hi, do you have a plan of the wiring?
Would be helpful
I just found this one: Nice Robus 600 Manuals | ManualsLib
Hi, I was helping with garage doors here. Maybe it will be useful for you. How connect an aqara relay T2 using 24V (solved) - #12 by gafich10
Thank you. Looks similar however not exactly the same. I’ll try as soon snow will melt ![]()
Hello, I’m happy to help, I gave a link as an example. If you need help, write to me in the topic Rele T2, let's talk about it again
Thank you, I will.
