Is there a opportunity to enhance the distance between chime and G410
Dear all,
Is there an Opportunity to enhance the distance between the chime and the doorbell g410
If not
A) when does the poe doorbell will arrive to the market
B) can I put the chime and the g410 into a separate wlan next to each other and let the home pod ring of course all in the same wired network . WiFi would be made via a Shelly 2PM
Hi
The Poe doorbell is currently under development, and it is too early to predict when it will be available.
It is possible to increase the distance between the modules, but this may affect the performance of the g410. The g410 can only be powered by wifi, and if you need to increase the distance between the modules, you can place them closer together. However, it is important to ensure that there is a stable wifi connection at this point to ensure the device’s proper functioning.
Here is a screenshot showing the recommended distance recommended by the manufacturer.
