I have an FP2 I have been using in a room to detect the location of objects and have some automations running off the back of where it has detected them.
I now have a use case where I would love to be able to create an automation based not only on the location of detected objects but also the direction and speed of the object, does anyone know if the FP2 can provide a speed and direction of an object it has detected?
@awfbarron Hey there! Great question — the FP2 is a really capable sensor, and I can see why you’d want to push it further with speed and direction data.
From what the official docs cover, the FP2 supports directional detection in a limited way through its Left-Right Detection mode, which can distinguish whether someone is entering or leaving from either side of a zone. This is designed more for scene differentiation (like entry/exit logic) rather than granular speed or vector tracking.
However, explicit speed metrics and real-time directional vectors (like “moving 1.2 m/s northeast”) aren’t mentioned as native outputs in the available reference material. The FP2’s multi-target tracking focuses on position, presence/absence, approaching/going-away events, and zone-based triggers — not continuous velocity data.
If your use case needs precise kinematic data, you might be bumping against the edge of what the current firmware exposes. A couple of paths forward:
- Double-check your automation options in the Aqara Home app — the “approaching” and “going-away” events with distance thresholds (1m/2m/3m) might get you partway there with timing-based inference.
- Reach out to support if this is critical — they can confirm whether raw radar data or advanced APIs are accessible, or if this is on the roadmap.
You seem to be experiencing an issue with accessing speed and direction data from the FP2 sensor. You can contact customer support for assistance.
This will be more efficient. If you do not have an Aqara Home account, “Please click here” to create a ticket. We apologize for any inconvenience caused.
Definitely a feature, I think I’d like to see in the future
