Issues with 3 out of 3 G5 Pro cameras with latest update
Hi, with latest firmware 3 out of 3 of my G5 Pro’s have issues, as in dropping down to 13.376fps framerate from 20fps after a while. Two separate physical location, both RTSP and NAS record files are affected. 13.376/20 means they are all dropping one in every third frame, causing the videos to be choppy. After a minute or so the framerate also goes down looking via the app.
Firmware version: 4.5.80_0018.0017
Algorithm version: 2.5.2
This is very disappointing and needs to be fixed quickly.
Hey, I made a ticket via the app earlier, I just made this topic to find more people with this issue in order to maybe help and speed up figuring out and solving the issue.
I can confirm the exact issue with 3 G5 pro cameras since same firmware version was updated every day i have to reboot or power cycle to get fps back from 13.4 to 20 fps very very disappointing and frustrating
I so glad to see someone else report this issue i been trying to contact Aqara on web support i gave up. Was regretting buying G5 pro x 3 as they are not cheap they all worked perfectly 24/7 until the firmware broke RTSP stream. Reputation is everything so hope Aqara can fix this soon
Well I guess I’m glad I’m not alone. My biggest problem at the moment is that I can’t downgrade firmware version. That I think should be very important, especially in cases like this. I have 190+ Aqara devices/sensors and sure there are some teething issues, but this is clearly an untested FW pushed live.
First thing i searched for was downgrade firmware yep impossible and as i writing this one of my camera is back at 13.4 fps so another reboot didn’t last 24 hours before the problem showed again. Come on Aqara get your act together and fix this
Yes, guys, we are fixing this issue urgently, the next firmware will be OK
