Klimaanlage mit Hub M3 verbinden?
Hi,
Hat irgendjemand eine Idee, wie man dem Hub M3 eine Klimaanlage hinzufügen kann? Ich scheitere an den kryptischen Anweisungen der App. Ich weiß nicht, ob die Klimaanlage an oder aus sein soll. Und was sind Entriegelungstasten? Die App ist entweder echt dämlich übersetzt oder ich bin einfach zu alt und mir fehlt eine Idee wie das Funktionieren soll.
Danke für jede Hilfe.
Gruß
Martin
@m_gorczelanczyk Please open the Aqara Home APP, navigate to the device page of Hub M3, select “Air Conditioning Mode” to enter, then choose the "…’ icon in the upper-right corner to access the settings page. Select “Matched AC” to initiate the AC pairing process, choose your home AC brand from the list, and follow the on-screen instructions to complete the setup.
@m_gorczelanczyk Hi Martin, sorry to hear you’re having a tough time with the app instructions—let’s break down what we know about the Hub M3 and AC connectivity.
The Hub M3 has a built-in 360° IR blaster that can connect to conventional IR air conditioning units, even exposing them to Matter for broader smart home integration. It can also function as an AC thermostat when paired with an Aqara Climate Sensor, using real-time temperature data to adjust settings .
For setup specifics, the reference info notes that more device functions (like IR pairing) are typically explored through the Aqara Home app . While the exact steps for adding your AC aren’t detailed here, ensure your phone’s Bluetooth is on (as the Hub M3 uses MagicPair for detection) and the hub is powered on with a stable Wi-Fi connection .
If the app’s translation is confusing, maybe the community has tips—have others here successfully paired an AC with the Hub M3? Feel free to share your experience!
Hope this helps, and let’s see if we can get you sorted. :blush:
Note: The above is based on available product info; for app-specific steps, you might also check the Hub M3 user manual for additional details .
