KNX Communication Issues - Successful Resolution and Tips
Hi everyone, I wanted to share my experience with resolving KNX communication issues in Home Assistant. I recently encountered a problem where adding a second switch caused instability in my setup. After hours of troubleshooting, I discovered that the issue stemmed from how the KNX addresses were configured in my configuration.yaml file. Here’s what I learned:
  1. Check Address Conflicts: Ensure that the address and state_address for each switch are unique and don’t overlap with existing devices in your KNX network. Overlapping addresses can cause conflicts and instability.
  2. Update KNX Binding: If you’re using an older version of the KNX binding, consider updating to the latest release. I found that newer versions have improved handling of multiple devices and better error logging.
  3. Review Logs Thoroughly: The logs provided invaluable insights. I noticed recurring errors related to group_read and state_address which pointed me toward addressing conflicts in my configuration.
  4. Test Incrementally: When adding new devices, test one at a time to isolate issues. This approach helped me identify that the problem wasn’t with the hardware but with the configuration.
  5. Use Cache Wisely: I disabled the cache option temporarily to ensure that the KNX bus was responding correctly. After resolving the issue, I re-enabled it for optimized performance.
By addressing these points, my KNX setup now runs smoothly with multiple switches. I hope this helps anyone else facing similar challenges! :rocket:
